ADL 3 Manual Beacon with switch
Postby Buzzdi on Thu Jun 18, 2015 1:37 am
i use a analog Input for the start line Beacon.
It is copied from the analog channel to beacon via a math channel.
My problem that is always triggered on a rising edge and not the falling edge when i release the button.
Any Ideas anybody how i can listen to the falling edge of the signal in the math channel?
Thanks,
Sebastian
Buzzdi
Re: ADL 3 Manual Beacon with switch
Postby David Ferguson on Thu Jun 18, 2015 3:31 am
You might try one of these:
- Make your Math Channel like this:
Input 1: Value 1
Calculation Type: none
Output Channel: Beacon
Condition: SwitchChannelName Updated and SwitchChannelName False
It's possible this may not work if beacon needs to have zero values. If so, you might try doing it with a User Condition setup like this:
Condition: Momentary
Activate the output...: SwitchChannelName Updated and SwitchChannelName False
- Consider changing the wiring so the switch activates a ground instead of a power. Add a pull-up resistor to your power source (or connect to an Analog Temperature or Switch Input).
Postby Buzzdi on Wed Jun 24, 2015 10:01 pm
Hi David,
thanks a lot!
It was not working as math channel, but the User Condition is perfect.
Thanks,
Basti
Buzzdi
Postby David Ferguson on Thu Jun 25, 2015 2:45 am
Glad that helped. Thanks for sharing what worked so other can learn, too.
Return to ADL3, SDL3 and CDL3
