by walkemazda on Tue May 26, 2015 1:06 pm
I have also been having problems with my active Lambda. I have an M4 running a rotary engine. I have done all the steps Adam suggested, but am still seeing the Active Lambda Off message when on the main fuel tables. But based on what Sprinter said, I went over to the Lambda Tables and it shows Active Lambda On. So in theory it should be working. But idling in the shop, when I make gross changes in the Lambda Table around the 0% throttle / idle speed cell, it has no impact on how the engine runs or on the actual Lambda reading. When I make a gross change when on the Main Fuel page, the engine dies. So the question is, when running on the Active Lambda Table, is there some threshold of throttle position and/or RPM under which Active Lambda does not work? That's the only logical explanation I can think of on why changing the Lamdba value in the Lambda Table does not change the way the car idles!
Thanks in advance for the advice.
