To me it just seems like "cripple code" when features that are standard even on the lowest price options require purchasing an upgrade to use.
I have a V12 that is FINALLY, after 8 years of work, approaching finished
viewtopic.php?f=42&t=1611and the M150 is a nice control option.  Its got channels for everything I could want so I sold the M800 and expanders I had waiting on the shelf and bought the M150 last year.  just staring to layout the install now.
As I go though and plan out the install there area  lot of ...hmmmmmmmm moments.
There are like 30 AN inputs, but there is not a generic setup of any kind, you have to call it something on the list. Ok fine that's minor enough but I can't call my NBO2 or WBO2  O2 signals because they aren't coming from a LTC....hmmmmmm.  I have a NB O2 in each header to help me balance the ITBs and WB in the 2 main collectors for4 actual tuning so the upgrade would be about $6000 which just isn't going to happen.  It looks like I can tell the ECU the 12 NB sensors are EGTs and display the output as mV on a temp (c) axis and I can send the WBO2 signals in as oil temp&pres and display lambda as lambdaX100 on a pres(kPA) axis and those will also log without the logging upgrade.  Ok fine.
Then same on the output side.  I want to have the ECU drive the Temp guage on the dash so I'm seeing what the ECU sees....hmmmmmmm....well if I tell the ECU its a coolant fan it looks like it should work, but that also means I get 1 actual coolant fan not 2, luckily I couldn't find space for the AC compressor so I only need 1 fan.  Not having generic stuff means a lot of digging through defined inputs/outputs looking for something that has meets the requirements and won't affect anything else.   There are 4 load or TPS vs rpm generics available so thats a help but its only 4 so I'm trying hard to other options wherever possible.  I spent a few hours the other day figuring out what all the predefined outputs do exactly to see what I could use where. but it looks like my fuel pum speed control, exhaust bypass valve and intake manifold valve will need to go on load v rpm...or wait, only 2 of those so I'll need to use TPS v rpm for one of them which I guess will be the fuel pump speed as that doesn't really matter much as I'm only trying to reduce fuel heating.
Clearly the goal here is to nudge me to buy the development package.
Don't get me wrong, the core functionality looks absolutely fantastic and I can't wait to fire the thing up but needing to pay extra for these  little things that are standard on even the cheapest ECUs these days is a bit frustrating to me.....it's pretty embarrassing to have to explain the an MS user that my M150 I can't do close loop without an $850 option that is about double what their whole ECU cost!
