by Gerald81 on Fri Feb 13, 2015 5:41 pm
Hi there,
Anyone knows if the M800 Plug In ECU for the 2006/07 STI will retain the use of the factory ABS and DCCD?
Regards,
Gerald
Gerald81
by KingMST on Thu Aug 27, 2015 10:28 pm
It doesn't seem that these forums are very active...
Yes Gerald, you will retain the ABS and DCCD.
What you will not be able to retain is your cruize control and secondary air pump function.
KingMST
