I would have thought I could find this somewhere or in the SDL tables but I have two 150psi Motec pressure sensors MEPT 150Gs. I cannot seem to find any 150psi sensors in the SDL config tables, strange considering its the Motec sensors. Does anyone have the config file for these? I know they should be linear. I tried to used the setup for a Honeywell 100PSI sensor and changed the 100psi voltage (4.509) to 150PSI and deleted all points between there and 0 (.5V) only having 0 volts and the voltage they used for 100 psi and it doesn't seem to be correct with the reading I am getting.
