Yamaha R1 14B pitlimiter setting M800
Postby Kip on Mon Nov 17, 2014 9:26 am
Does anybody know how you can get the M800 pitlimiter working like this on the R1 bike ?
You hear limiter kicking in at 14sec point of the video .
https://www.youtube.com/watch?v=4VXqaZmebzw
Kip
Re: Yamaha R1 14B pitlimiter setting M800
Postby DimST on Tue Dec 23, 2014 3:03 am
Hello Kip,
You first need to add an AT input switch with parameter: 16 : Ground Speed Limit Enable (for your switch)
Then you will find a fuction called ground speed limiting which is used when you use ground speed limit input.
I believe from there it's quite easy but let me know if you need further help
DimST
Postby Kip on Wed Jan 14, 2015 6:01 am
DimST wrote:Hello Kip,
That I knew mate :)
The ground speed limiter is working with me but the problem is its sounds horrible , the bike humps up and down ,
I got it on :
rpm limit type 3
randomizer 75
controle range 100
I think the problem is the randomizer numer , the ignition and fuel look like getting cut to long .
I got a 2013 R1 and like you hear on the youtube film I posted that R1 sounds how I would like to get mine sounding when ground speed limiter on .
Kip
Return to Tuning discussions
