ADL3 Missing bottom bar of 0 on gear shift display
Postby mr2cje on Mon Jan 05, 2015 1:56 pm
Hi, I have an ADL3 which is showing the gear position.
I just upgarded the firmware to the latest version V5.60.
After i upgraded it, now when you go to neutral and position 0 shows up on the dash the bottom line is missing on the display.
When i do a Dash check it's ok. When it selects 3,5,6 which all use this line, they all show up correctly. Its only the 0 position.
Any ideas?
mr2cje
Re: ADL3 Missing bottom bar of 0 on gear shift display
Postby mstech on Tue Jan 06, 2015 8:47 am
The new firmware update changed the display of the neutral position indicator from a 0 to N which is made up of a 0 with the bottom line missing.
mstech
Postby mr2cje on Tue Jan 06, 2015 3:40 pm
Thank-you that makes sense, but it doesn't look much like a N. Preferred the 0 myself but.. anyway...
mr2cje
Return to ADL3, SDL3 and CDL3
