M4 com port 2 query
M4 com port 2 query
Postby terryo on Thu Dec 18, 2014 5:21 pm
how do we change the Motec software so we use com port 2 on a machine running XP
com port 1 is already used by another device (mouse??)
thanks
terryo
Re: M4 com port 2 query
Postby mstech on Fri Dec 19, 2014 8:47 am
The F5 key brings up the list of Com ports when you are in the program integrator screen.
mstech
Postby terryo on Fri Jan 02, 2015 10:14 am
thanks, but i need more..
when i load the M4 software i get a choice of 4 versions. whichever version i select i get this windows message
"'the system cannot open COM1 requested by the application"
i get the choice to close or ignore. if i select ignore, i can sometimes get to the program but i still cant conenct to the M4 using either a serieal port or a USB to serial adaptor
what is the "interrogator screen"
terryo
Postby David Ferguson on Fri Jan 02, 2015 5:41 pm
terryo wrote:what is the "interrogator screen"
It's the screen where you pick which of the programs you want to run, Interpreter, etc. I think it's the same screen where you are choosing from the multiple versions. Try the F5 key at that point, or if there was a screen before where you selected to edit the ECU...
Postby terryo on Fri Jan 02, 2015 11:47 pm
thanks, tried that, F5 does nothing on any screen
terryo
Postby AdamW on Sat Jan 03, 2015 6:41 am
Are you using of the most recent EMP version? I think the manual port selection feature only came in V6.20:
Motorsport Electronics Ltd.
AdamW
Return to MoTeC PC Comms
