wiring IGN 1A coils
wiring IGN 1A coils
Postby Noslin on Fri Nov 14, 2014 5:40 pm
looking for some input on where to put letter "B", Logic ground. Im taking it ignition signal is A1-4 ( 4 cyl). would "B" go to A10 or A11 or could it connect to batter negative, same as "D"?
Here is the connector pinout:
A - Ignition signal from ECU
B - Logic ground, connect to ECU ground
C - Spark wire ground, connect to cylinder head
D - Power ground, connect to battery negative
E - 12 volt power
ty
dean
Noslin
Re: wiring IGN 1A coils
Postby PQatPIT on Sat Nov 15, 2014 11:23 am
I connect A10 and A11 with separate wires to cylinder head or block.
If IGN 1A or similar coils are used then I connect B terminal to this point also, with its own separate wire. Do not connect any other wires to this grounding point. Ignition ground ie. C terminal goes to cylinder head, again no other wires to this grounding point.
Never had any grounding or ignition related problems when done it this way.
PQatPIT
Postby Noslin on Tue Dec 23, 2014 12:28 pm
i ended up taking "B" back to the ecu ground as i figured it would need to see it if you were to create a map for the coil dwell???
ty for your reply
dean
Noslin
Postby Scott@FP on Fri Dec 26, 2014 5:33 am
'B' is for 0veng or 0vaux. For dwell table to have validity, your 12v source at 'E' to the coils needs to read the same as what the ECU sees, just like injector batt comp. Might be wise to feed B+ to ECU, coils and injectors from the same relay output to make all the voltage compensations proper.
Scott@FP
Return to M84 ECUs
