David Ferguson wrote:So it sounds to me like as you are changing the cam profiles, you need to also reduce the mechanical range the VANOS is allowed to move. Is there some way to fit a pin, or machine a spacer/stop to reduce the operating range?
Herrubermensch wrote:... the bank 1 vanos seemed to allow the helical gear to go too deeply into the exhaust cam, allowing the cam gear to rotate beyond its factory rotation range, then stick and refuse to move. Piston to valve contact, resulting in smashed valve and cracked block and damaged pistons, all within 1:52 of startup.
Herrubermensch wrote:I absolutely will be using the M1 to manage maximum retard and advance.
