Hi
Tried too increase the dwell time?
I did run a rally car with R6 coils.
I used:
7v 8V 9V 10V 11V 12V 13V 14V 16V
12,7 8,9 7 5,9 4,6 4,2 3,8 3,4 2,9
Don't know if th coils are the same but you can try!
AF
Arve Flaat wrote:Hi
I used:
AF
cra5hdown wrote:Yes I would start with the battery. I had a similar problem and a battery change fixed it. Also the starting when hot. On my r1 I had to go into neg numbers on the crank comp to get it started when hot. so you should try that
cra5hdown wrote:It is a anti gravity 8 cel battery.
What did you set your starting comp?
How well does it do hot starts. Do you have a log of the engine running at idle warmed up? I would like to have a look at it if you don't mind.
cra5hdown wrote:my idle fluctuates a little but is steady. i wanted to compare mine with yours but the file does not seem to be working
Users browsing this forum: No registered users and 31 guests
