Yamaha R1 14B M800 starting problems .
Re: Yamaha R1 14B M800 starting problems .
Postby Arve Flaat on Fri Nov 14, 2014 7:50 am
Hi
Tried too increase the dwell time?
I did run a rally car with R6 coils.
I used:
7v 8V 9V 10V 11V 12V 13V 14V 16V
12,7 8,9 7 5,9 4,6 4,2 3,8 3,4 2,9
Don't know if th coils are the same but you can try!
AF
Arve Flaat
Postby Kip on Fri Nov 14, 2014 8:09 am
Arve Flaat wrote:Hi
I used:
AF
No , that I didn't try yet , I think they are the same .
My problem is completely the same as this thread , so I think battery problem
viewtopic.php?f=11&t=1940
Kip
Postby cra5hdown on Fri Nov 14, 2014 12:01 pm
Yes I would start with the battery. I had a similar problem and a battery change fixed it. Also the starting when hot. On my r1 I had to go into neg numbers on the crank comp to get it started when hot. so you should try that
cra5hdown
Postby Kip on Fri Nov 14, 2014 6:33 pm
cra5hdown wrote:Yes I would start with the battery. I had a similar problem and a battery change fixed it. Also the starting when hot. On my r1 I had to go into neg numbers on the crank comp to get it started when hot. so you should try that
What battery did you use ?
I ordered a Super B 5200 , hope this wil work .
Kip
Postby Kip on Sat Nov 15, 2014 10:13 am
Problems solved I think .
Bike starts pretty good now and crancks almost 2 times the RPM it did before .
Only thing I had to do was service my starter motor .
Now a normal R1 battery can get it crancking up high enough to start even with my engine and its a full Yec engine .
Kip
Postby cra5hdown on Sat Nov 15, 2014 12:51 pm
It is a anti gravity 8 cel battery.
What did you set your starting comp?
How well does it do hot starts. Do you have a log of the engine running at idle warmed up? I would like to have a look at it if you don't mind.
cra5hdown
Postby Kip on Sun Nov 16, 2014 1:42 am
cra5hdown wrote:It is a anti gravity 8 cel battery.
Here is the logged file I made today , this was with a stock battery not completely full as you can see .
I stopped it 2 times at the end arround 77°C and started it back up as you can see .
Idle isn't running that bad , the bike is running to riche in fuel because it has no air tubes on it and all the heat from the engine gets to the collector box and it was mapped without DB killers wich are now mounted on it .
Also I'm working in a small closed workplace so the oxigen is pretty low and that also may add in the rich running I think .
Do you got idle problems ?
Kip
Postby cra5hdown on Sun Nov 16, 2014 3:00 am
cool, im trying to download it but it is not letting me. can you check if the file is correct. thanks
cra5hdown
Postby cra5hdown on Sun Nov 16, 2014 4:15 am
my idle fluctuates a little but is steady. i wanted to compare mine with yours but the file does not seem to be working
cra5hdown
Postby Kip on Sun Nov 16, 2014 10:01 pm
cra5hdown wrote:my idle fluctuates a little but is steady. i wanted to compare mine with yours but the file does not seem to be working
Mine does also fluctuates a little .
I'll try to upload again
77°C.ld.ld
(634.8 KiB) Downloaded 1103 times
Kip
PreviousNext
Users browsing this forum: No registered users and 35 guests
