I want to start a project on a BMW M6 V10 in a 3series body. Can anyone help me with the setup and requirements for Running a BMW M6 V10 on Motec? ref/sync, Cam control, Drive by wire... etc
Is the Cam position measurement and control similar to n52? Ive got quite a bit of experience on the BMW n52 (3 Litre straight 6 found in the e90 BMW`s)
Why does the DBW need to be modified? I guess you`d have to add ignitors to the drive the coils?
Can the Motec run the V10 on OEM trigger wheels and sensors?
DO you use the 6-1 on the Exhaust for Sync? Ref is 60-2? Is the DBW Mod done on the butterfly internally? Just as a matter of interest....did you see big gains over OEM when you have done these engines?
