I set up an "Elapsed Time" timer which starts on the first beacon hit and works properly (start condition= "Beacon Updated and Lap Number = 0"). On the bottom line of my dash I am displaying Minimum Lap Time and Ground Speed. I want to override those values on every beacon hit with the "Elapsed Time" timer and hold it for 10 seconds before reverting back to the original values (Min. Lap Time & Ground Speed). The Problem: It overrides just fine on the first pass by the beacon, but it never reverts back to the original bottom line values. The only theory my crew chief has on this is that it might have something to do with the fact the timer is constantly updating. Note, however, that the override condition is set to "While the following channel is true: Beacon", Not "When any one of the values is updated", which should eliminate the "constantly updating" theory as a problem.
Here is a screen shot of the Display Setup:
And here are the Override Settings:
Does anyone have any idea why this won't work? For the record, I also tried eliminating the Minimum Lap Time (Value 1) on the override and making the Timer the only value without success.
Any help would be much appreciated!
