Hello all,
I'm trying to import data from two other codes into Motec to compare real world data, with an in-house simulation code with simulator (rfactor - Motec) data.
Is there any plugin or functionality that I can use to import data from other codes? What formats are available?
Both other software can export as .csv files, this appears to be the common ground between the other two....so can I import into Motec?
