I am trying to use the air con request function to drive the air con compressor clutch.
I have a dig input working and the AC request status shows in the status page when the input is triggered.
I have also tested the output (working through an E888 expander) and the clutch is triggered correctly. I can also manually change the polarity in the output set-up and engage the clutch.
So the input and output are both working - but they don't talk to each other! Activating the a/c request does not result in the clutch engaging.
I have appropriate values set in the rpm and throttle position settings for the a/c control.
What am I missing? This one has me absolutely stumped.
