M48 and Lambda
M48 and Lambda
Postby Andrew C on Mon Sep 22, 2014 5:26 am
Looking to run the AEM UEGO - Inline Wideband Controller with our M48 and Pista setup. Anyone have experience with this controller?
Adam, car is running well, issue was the sync pins (bad crimps)
Andrew C
Re: M48 and Lambda
Postby AdamW on Tue Sep 23, 2014 9:32 am
Andrew,
I have used a few of AEM 30-2310 inline wideband controllers with a M48 (and other ECU's) and have found them to be a really good reliable unit with reasonably good accuracy. They are my pick of the bunch from the common 'budget end' wideband's available right now.
However be aware that it will take some extra work to get a M48 working with more modern wideband controllers since it only accepts about 1.2V max into it's lambda input whereas most widebands including the AEM give a 0-5V output.
You will need to use a 5:1 voltage divider and also mess around a bit in the M48 user defined lambda table to get the Motec lambda display to match the AEM. When I do it I use two laptops so I can view the AEM via its serial connection at the same time as the Motec on a second laptop. You can PM me if you need some help since it might get too involved to try to cover it in a forum post.
Motorsport Electronics Ltd.
AdamW
Re: M48 and Lambda
Postby Andrew C on Tue Sep 23, 2014 10:54 am
Thanks Adam.
Do you use 2 resistors in your divider? I may need to reach out for design ideas for this application.
Andrew
Andrew C
Re: M48 and Lambda
Postby AdamW on Tue Sep 23, 2014 8:27 pm
Yes, I have used two resistors but you could also just use something like a 20kohm trimpot. See the bottom of this page to see how it looks: http://wbo2.com/faqs/autronic.htm This example shows a 10:1 divider so if you change the resistors to say 16.2k & 4.02k that will give you close to 5:1. Preferably use 1% 1/4w resistors
AdamW
Users browsing this forum: Google [Bot] and 7 guests
