Detonation on fast gear change
Postby JulianEdgar on Sun Sep 07, 2014 8:03 am
I have a transient detonation problem on fast (eg 1-2) gear changes.
Can you pull back timing based on rate of accelerator pedal movement, or is there some other approach that will work?
M400 on Honda Insight turbo.
Thanks for any advice!
JulianEdgar
Re: Detonation on fast gear change
Postby stevieturbo on Mon Sep 08, 2014 1:22 am
There is an advance/retard feature much the same as fuel transients that should do what you need
Adjust, Ignition, Accel advance
open the window and hit F1 for info
stevieturbo
Postby JulianEdgar on Mon Sep 08, 2014 6:22 am
It doesn't do negative numbers though - ie you cannot retard on acceleration, can you?
JulianEdgar
Postby stevesingo on Mon Sep 08, 2014 7:48 am
Menu
General Set Up
Ignition
Set Up
Ignition Accel Mode: You have the option of retard on Accel, Advance on decell or Advance on Accel and retard on decell.
stevesingo
Postby JulianEdgar on Mon Sep 08, 2014 7:59 pm
Thank you!
JulianEdgar
