Yep,
So this is the thing. It's a Suzuki GSXR600 2k5 engine with a M84.
If I open the throttle to make it rev to 11-12000rpms, when I let the throttle go back to idle, it will just die. It becomes a problem when I shift down near to a massive curve, the engine dies and thanks to the inertia I just release the clutch and the engine will start again, but I lose time with this (it's a racecar).
No ref/sync problems, seems like just a tuning issue.
What compensation should I use? I thought of Deccel clamp but I actually don't know if it dies because there's too much or too less gasoline.
Thanks!
