I am running out of outputs on the M400 / CDL3 dash.
I have been reading here about the E888 / 816 expanders and it appears that their use is not particularly seamless with the hundred series ECUs.
If I get (say) an E888, can I drive the 8 outputs it has with full 3D tables programmed in ECU Manager? If so, where are those tables in ECU Manager? I don't quite understand how those tables are created. Or do they replace existing functional tables?
Or do those expander outputs work under the normally available Aux output functions (except where stated otherwise)? ie these functions:
1 : Boost Control
2 : PWM Idle Speed Control
3 : Aux Table
4 : Tacho Signal (Not suitable for Aux 5,6,7,8)
5 : Drive by Wire (Aux1 only - uses Aux2 also)
6 : Drive by Wire Idle Speed Control (Aux2 only)
7 : Idle Slave
etc
If so, there's only 8 Aux outputs in the software - where do the extras come from?
Thanks for any help people can offer me.
