Hi All, I have an RB26DETT with the air flow meters removed but retains the STD manifold, what is the best setup for maping is it map or throttle, or is there another way
Paul
Chris Wilson wrote:How big a difference does running separate throttle position / RPM based map make? Any info on the best way to do this, I am assuming it helps part throttle light boost situations? Is it worth it on a race engine used for circuit work? Would it be worth it on engines with a single throttle plate (mine is still on stock RB26 multiple throttle bodies). Thanks.
Users browsing this forum: Google [Bot] and 15 guests
