My Honda Insight uses a 12 tooth trigger on the crank (no gaps or additional teeth).
The cam uses two teeth, arranged as if there were three teeth at 120 degree intervals but with one missing. Two separate cam sensors are used - TDC #1 and TDC #2.
How do I use this system on the MoTeC M400?
The Honda S2000 uses a similar approach, but with three teeth on the cam not the Insight's two teeth. (The Hundred series ECUs have a specific mode for the S2000.)
Note that in the Insight the two teeth are cast into the cam, so removing one tooth would be a reasonably major exercise.
Thanks for any help anyone can offer.
