Hi, I have tried to change my profile info to give some info about me but it keeps asking me to log in to do so.
Car: 2004 Subaru WRX STi with every single thing changes I could
Occupation: Manager @ car dealership
Tuning Skill: Some learning as I go.
Diagnostic Skill: Relatively high gone through alot with this car.
About the Car:
Sleeved USDM ej257 block 9.5:1
+2mm Rods
Over sized valves on USDM WRX 25b heads
Single AVCS
Halleffect cam sensor
mag crank sensor
GTX3576r
45psi fuel pressure
ID2000 injectors
motec m800
motec PDM30
CDL3 dash
motec Wideband sensor
aem oil temp, oil pressure, fuel pressure, boost control solenoid
laille crank pulley
motiv TGV housings
Cosworth intake manifold
Custom Twinscroll Manifold
dual Tial 44mm wastegates
Onto my issues.
my idle, which I believe is coming from my DBW throttle set-ups.
as well as the ID2000 injector setups
The way that the Subaru adjust Idle is with the actually TB butterfly on these DBW cars. The butterfly on the TB stays open a crack and never closes.
My tuner thought that the TB was warped and that was causing this issue. However it is not, all of these TBs stay open a crack, so he didn't try to dial in the idle any better saying that he couldn't because the TB was broken.
The car also has a terrible bucking problem at low throttle inputs especially in 2nd gear where you spend most of your time when you are in any sort of stop and go traffic or puttering through a neighborhood to get home. It isn't as bad in the other gears as you typically have to give more throttle input to go the same speed at such a low speed.
Any help would be great.
