by stevieturbo on Wed Jun 25, 2014 10:10 am
I would never want to run idle timing near zero, more typically in the 10-20deg range.
TBH really wouldnt worry too much about injector dead times, everyone tuned without them for years with no problems and if battery voltage is table, it will be a single figure used anyway. But yes it would be nice if you had the correct information
Is injector current set correctly ? ie for high or low impedance injectors ?
Injector timing sensible ?
Ignition timing confirmed as accurate ?
And what is the problem with idle ? unstable ? too high ? it stalls ? are you trying to use some form of idle control ?
And bin the narrowband ( even more so if it isnt a heated sensor ), get a wideband.
And make sure any closed loop functions are turned off until you have some sort of sensible base setup working.
