VW VR6 3 litre 12 valve turbo.
I had pretty well made up my mind that the M600 with SKM is the ECU I need to use as the engine is 6 cylinder and I want to be able to fire the original triple coil wasted spark coil pack unit plus have single wideband lambda, DBW, traction/launch and knock. The problem is I would like everything on one board and so the M800 provides this with the OKM BUT in the case of both the SKM and OKM I cannot see if the use of dual knock sensors is possible as this is necessary and how the engine was equipped originally. Can anyone enlighten me?
