Ok, so I have a new to me pro mazda with ADL (original) and billet shift light. The car runs an M400 ECU.
when I turn on the main power at the battery disconnect, the dash powers on and the billet shift light exhibits light 3 at approx. 30-50% bright and light 4 (the center 3 red led's) at a very dim setting. When the fuel pump first runs to build pressure (before starting car thought, just at first power up), light 3 brightens and stays bright (the 2 green led's 3rd position from each end).
I am convinced there is nothing in my dash config that would cause this. I am unsure if my M400 would be causing it, but I couldn't find any output settings in that file that made me believe it might be causing it either. I suppose next is to start tracing wiring and see if there is a ground issue? Files attached if anybody wouldn't mind taking a look.
Cheers,
Mike
