Engine RPM on BMW E30
Postby fdv99 on Thu Jan 30, 2014 5:30 am
I have a C125 Dash logger with the i/o upgrade, and am having trouble getting an RPM signal to the logger. The car is a 1989 BMW 325 so it has no OBD port or easy way to get RPM. There is a wire coming from the ecu that fed the stock tachometer in the dash. This wire shows 12 volts DC when the engine is off and decreases as the RPM increases. The best measurement I have shows roughly 8 volts at idle and continues decreasing as the RPM increases.
I was told that I could run it to a digital input and calibrate it, but when I go into the Dash Manager and select RPM for a digital input I can't figure out a way to calibrate it.
Any help is appreciated.
Forrest
fdv99
Re: Engine RPM on BMW E30
Postby mstech on Thu Jan 30, 2014 10:07 am
I do not think that you can use a digital input as they do not read voltages, only frequency of change. Use one of the AV inputs, allocate it to the engine RPM channel and then make a table that is based off of your V vs. RPM readings.
I have enclosed a quick file showing what I believe you need, just rename the file extension to .c2u as these files are blocked by the forum software.
RPMv.pdf
Rename the file to RPMv.c2u and import into the Dash manager
(528 Bytes) Downloaded 1853 times
mstech
Postby fdv99 on Thu Jan 30, 2014 11:02 am
With it going up to 12 volts, and around 8 volts at idle, will the AV input handle it okay and not damage anything?
Thanks for the help.
fdv99
Postby SprinterTRD on Thu Jan 30, 2014 11:36 am
I doubt it would be a varable voltage!
I would put your meter on frequency measurement and see what it reports.
What you see is the multymeter averaging the frequency.
SprinterTRD
Postby fdv99 on Thu Jan 30, 2014 12:12 pm
Okay, I'll check again with it on frequency in the morning.
If this doesn't work, someone suggested picking up a pulse signal from the negative side of the coil, would that work to a digital input?
fdv99
Postby SprinterTRD on Thu Jan 30, 2014 1:08 pm
No, Do not put coil neg into the digital input!
You will blow the input up as it is not designed to handle the 400V coil neg pulse.
SprinterTRD
Postby Hoolio on Fri Jan 31, 2014 6:28 pm
The wire from the ECU which feeds the standard tacho is most definitely variable frequency (conventional one pulse per cylinder firing) so that is the connection you need to make to your dash logger. You just need to figure out how to calibrate your dash logger; sorry but I can't help with that.
Hoolio
Postby fdv99 on Fri Jan 31, 2014 11:06 pm
Ok, great. Thanks for the help everyone, I'll hook it up and play with the calibration
Forrest
fdv99
