C125 to Pectel GCU
C125 to Pectel GCU
Postby MichaelLee on Wed Jan 22, 2014 4:41 pm
The Pectel GCU require some data from C125 Dash by CAN Bus. But I am not familiar with CAN setup. Could you tell me how to setup the transmit of CAN? I have attached the CAN information of Pectel GCU. The GCU require data: Rpm, Gear,TPS. Thanks.
Pectel GCU to ECU CAN Link.pdf
(88.72 KiB) Downloaded 1130 times
MichaelLee
Re: C125 to Pectel GCU
Postby AlanB on Fri Jan 24, 2014 3:46 am
Hi, if you give me your email address I will send you a C125 configuration file with the CAN Tx setup.
Alan Bell
MoTeC Europe Ltd
AlanB
Postby MichaelLee on Fri Jan 24, 2014 2:36 pm
Thanks, Alan. I have pm to you
MichaelLee
Postby AlanB on Fri Jan 24, 2014 7:19 pm
Config sent Michael, I hope it helps.
Alan Bell
MoTeC Europe Ltd
AlanB
Return to ECU to Dash Comms
