Mitsubishi EVO 5 idle air valve
Postby Simon Wenzel on Tue Jan 14, 2014 5:47 pm
Hi all
We are installing an M800 (not plug and play) onto an EVO 5 Lancer. Just after some info concerning the factory 6 pin idle stepper motor. I believe 2 of the 6 pins are ignition 12 volts, but are there specific aux output chanels that need to be connected to the remaining 4 stepper motor pins. Anyone have a wiring diagram or info?
Simon
Simon Wenzel
Re: Mitsubishi EVO 5 idle air valve
Postby Scott@FP on Sat Jan 18, 2014 5:55 am
This is specific to 8/9 but should be the same pinout, verify if needed.
************Disconnect the two B+ wires from the 6 pin ISC connector.******************
Aux 5 - ISC connector pin #1
Aux 6- pin #3
Aux 7- pin #4
Aux 8- pin #6
If pins are in wrong position it just wont work, nothing bad should happen.
Scott@FP
Users browsing this forum: No registered users and 39 guests
