In between gears
In between gears
Postby mr2andy on Thu Jan 09, 2014 7:18 am
All,
I'm doing some street tuning trying to improve the drivability of the car. What I have notice is, in between gears, the rpm doesn't comes down quick enough. For example, let's say I'm in 2nd gear closing 4k rpm, when I let go of the throttle and engage the clutch in getting ready to switch into the 3rd, the rpm doesn't come down quick enough. It stays at 4k rpm and slowly decreasing when I engage the 3rd gear. Things seems fine but just thought the rpm didn't come down quick enough.
Which part of the tuning should I work on to cure this symptom?
Andy
mr2andy
Re: In between gears
Postby mr2andy on Thu Jan 09, 2014 8:44 am
It may have to do with not having an idle air valve controller and the throttle body is not 100% close when the foot is off the pedal. I wonder if there is any tuning trick which can address this. :)
mr2andy
Postby stevesingo on Thu Jan 09, 2014 6:02 pm
Log idle valve position to see where the valve sits at 0% TPS but outside of the idle control range.
In idle control menu there is a "initial Position" parameter. Set this to a duty cycle sufficient to fully close the valve when outside of the control range, use the same value as the minimum duty parameter.
stevesingo
Postby stevieturbo on Thu Jan 09, 2014 10:25 pm
Overrun fuel cut would easily override any "air leak" issues if that was the actual cause.
stevieturbo
Postby mr2andy on Fri Jan 10, 2014 3:31 am
Steve, thanks for the input but I don't have idle air controller on my setup.
mr2andy
Postby stevieturbo on Fri Jan 10, 2014 5:42 am
mr2andy wrote:Steve, thanks for the input but I don't have idle air controller on my setup.
No idle speed control valve ?
Either wayl, overrun fuel cut will resolve the problem. Set it to restore at say 2-2500rpm. So close throttle anything above that rpm, and a full fuel cut will occur. The engine rpm can do nothing other than fall.
stevieturbo
Postby SprinterTRD on Fri Jan 10, 2014 9:45 am
On some cars there is a small throttle kicker that is vacume operated to hold the throttle open see if your car has one.
SprinterTRD
Postby Holmz on Fri Jan 10, 2014 7:32 pm
What type of DBW throttle body do you have?
Holmz
Postby mr2andy on Sat Jan 11, 2014 2:22 am
It's not DBW. It's a mechanical throttle body. It currently doesn't have idle air valve/controller on the setup but I do plan on adding one in the future.
I have read more about overrun fuel cut, is it really suitable to use for in between gear?
mr2andy
Postby stevieturbo on Sat Jan 11, 2014 6:20 am
mr2andy wrote:It's not DBW. It's a mechanical throttle body. It currently doesn't have idle air valve/controller on the setup but I do plan on adding one in the future.
Every OEM car uses this, and most aftermarket.
It is generally for emissions and fuel economy. But as long as it's operation doesnt give you any noticeable bad feelings, then use it.
stevieturbo
Return to Tuning discussions
