by JamieA on Tue Jul 22, 2008 11:39 am
The MoTeC SDL has the ability to read information on RS232 and CAN from other brand ECU's no problem, but let me know what you have in mind, as some ECU's don't use streaming RS232 data which makes getting data at a reasonable speed for either logging or display not worthwhile.
If price is the key, then you will certainly find cheaper that MoTeC. But like most things in life you get what you pay for.
If you are intending to use the datalogging featres of the dash, you should download the data logging software from us (i2 Standard), and AIM's equivillent, and also the Dash2. Using the provided sample files, you will quickly be able to see where the extra cost has gone just in the datalogging software alone.
Next download all of the display manager softwares, try setting up the different types, and have a look at the limitations you have with the cheaper devices
Dash2 with a DL1 to drive it is about $2300 aud (off the web site)
An AIM MXL is about $1999aud (off the web site)
A non logging SDL is in the same region price wise, with an extra cost for the logging option. Due to differing prices in different countries (due to freight, taxes etc), give your local dealer a call for your local price.
So ours will be more expensive, but not enormously so. But if you compare the hardware, software and features, of the SDL with i2 you will find that it is absolutely worth the extra.
Jamie
I
