M1 Tune has a delightful toggle in setup between using MAP or throttle angle for load on the Y-axis in the VE table. In the M1 Tune setup webinar, Motec suggests that when tuning an engine with individual throttle bodies, MAP resolution tends to be poor and throttle angle is the best approach for load. Many an S62 has been tuned with Motec ECUs, maybe even an M190 or two! My question is: What did people use to determine load, MAP or throttle angle? The S62 has two pipes running underneath each bank of TBs from which vacuum/boost for the fuel pressure regulator is taken and the vacuum connection for a BOV, if the engine is supercharged. What is the experience of those who of have tuned S62s with a Moted ECU? Will a MAP signal taken from the two pipes connecting all the TBs be of sufficient quality to use for load in the VE calculation? There HAS to be some wisdom out there on this topic. Thanks.
--Peter
