Setting up M130 on Yamaha FZR
Postby Kroozer on Mon Nov 11, 2013 11:09 pm
Hi, Need Help
Q1. How do I hookup the 5Hz GPS from my M400 to the new M130? :ugeek:
Q2. What input should I use for the 9 position switch? I have tried several inputs and created a table for the varying voltage levels and have fount that they have been rounded up to the nearest decimal place e.g. "2.4volts instead of 2.365volts". :shock:
Q3. What input should I use for launch control and do i need a pull up resistor? :roll:
Any help and comments welcome
Kroozer
Re: Setting up M130 on Yamaha FZR
Postby Kroozer on Wed Nov 13, 2013 2:05 pm
Anyone...
Surely Motec gotta know
Kroozer
Postby Kroozer on Thu Nov 14, 2013 2:36 pm
$4K Ecu and responses like this. :cry:
Kroozer
Postby SprinterTRD on Thu Nov 14, 2013 5:02 pm
You should read the information on the FZR
"• GPS receive configurable via CAN through MoTeC Serial-to-CAN (STC) device for speed and track mapping"
SprinterTRD
Postby Kroozer on Thu Nov 14, 2013 6:13 pm
With the M400 the GPS plugged straight in. No additional wiring or costs. :oops:
So now I have to buy some more bits. :cry: I hope it works on the 5Hz GPS
Kroozer
Postby Holmz on Sat Nov 16, 2013 10:29 am
Kroozer wrote:With the M400 the GPS plugged straight in. No additional wiring or costs. :oops:
Unless one needs the RS232 for something else, which was me.
Then you use the STC for the GPS and the port for the other device.
it worked for the 10Hz GPS, you could contact MoTeC if you are not sure...
Holmz
Postby Kroozer on Sat Nov 16, 2013 11:00 am
Thanks Holmz,
I only need the GPS. It's a shame that it cannot be plugged into a spare digital input and read the RS232 protcol after all it's only a square wave. One of the dealers I purchased it from is unsure and also awaiting a response. :?
The STC is on it's way will know soon.
Kroozer
Postby Kroozer on Sat Nov 16, 2013 11:04 am
Q1. What input should I use for the 9 position switch? I have tried several inputs and created a table for the varying voltage levels and have fount that they have been rounded up to the nearest decimal place e.g. "2.4volts instead of 2.365volts". Maybe this is ok....??????
Q2. What input should I use for launch control and do i need a pull up resistor?
Any help
Kroozer
Postby Martin on Mon Nov 18, 2013 3:07 pm
Q1. Just press Q, it will take the further decimals into account. You can also type numbers with more decimals, even if you cant see them they will go into the ECU.
Q2. UDIG input. No, they have software selectable pullups.
Postby Kroozer on Wed Nov 20, 2013 1:03 pm
Many thanks Martin I will give this a go. :)
Kroozer
