200 Hz is 6000 rpm on a 4 cylinder tacho and 3000 rpm on an 8 cylinder tacho.
This 4 cylinder may spin to 9500 rpm on the stock (MX5) tacho.
My question was do the ign outputs have the 200 Hz cap?
Wolf_Tm250 wrote:
how could i drive it with a low side signal, if it needs positive 20v?
MarkMc wrote:Just be a bit careful,
Depending on the age of the car the Tacho may be a coil negative drive tacho which means it works on the big back EMF voltages you get when the coil fires. If it is a coil negative tacho the simple pull-up to 12v may not work. You may need to add an inductive coil like the control side of a relay (see attached drawing).
If you use a realy you will be best to get the metal bodied ones where you can remove the body to rip off the high current switch otherwise the relay buzzes away at the frequencey of the tacho.
SprinterTRD wrote:The relay trick should work on most coil neg style tacho circuits, are you sure the relay was a non suppressed type?
Some relays have diodes or resistors across the coil to reduce the voltage spikes.
Also the relay trick wont work on some of the ECU outputs as they have inbuilt protection diodes.
