Holden Ref/Sync setup
Postby Fahad on Tue Oct 28, 2008 7:22 pm
Hi there, I am looking for information on the Ref/Sync set up for the Holden VE Commodore 6.0L
Your help is greatly apprciated,
Fahad
Re: Holden Ref/Sync setup
Postby Fahad on Thu Oct 30, 2008 6:31 pm
wow 31 views and no replies. The engine is a Gen 4 . 60-2 crank and 4 tooth cam.
Fahad
Postby Motec_Master on Thu Nov 13, 2008 7:31 pm
Fahad email me I will send you a start file abudhabiracing@gmail.com
Wiring is a bit different too in ref and sync. If you need help in that also please ask
Regards Rashed
Motec_Master
Postby Fahad on Fri Nov 14, 2008 6:46 pm
Thanks Rashed, I have started the car with no problems.
Fahad
Postby MarkMc on Mon Dec 01, 2008 2:55 pm
Just if anyone is wondering, the newer GM V8's have the BMW Mode 17 for the ref and sync. 60-2 on the crank with a magnetic sensor and four sync teeth, two long and two short, the sync edge is which ever one in NOT evenly spaced. This mode has turned up on quite a few other engines, like the VW VR6 with switched cams.
Postby Ellis7 on Wed Dec 17, 2008 9:11 pm
Hi, does anyone have any idea of what CRiP setting to use (as a start) when using the standard L76/L98 sensors (M800)? :| I know the older 24 tooth systems used a 455 degree CRiP angle. Cheers
Ellis7
Postby Fahad on Thu Dec 18, 2008 6:11 pm
Try 70 or 430
Fahad
Users browsing this forum: Google [Bot] and 68 guests
