Suggest a small magnetic ref sensor.
Postby Sean on Tue Aug 20, 2013 8:45 am
Hi, I am after suggestions for a small magnetic ref sensor, about 12mm diameter, maybe 40 ish mm long, preferably with a threaded body. I can't really make head nor tail of RS or Farnell's catalogs :(
It's for a drag bike application, so will see up to 14K rpm at times, and it's a harsh environment with heat and vibration. Using a simple 8 tooth trigger wheel, and M400.
Thanks for your suggestions.
Sean
Re: Suggest a small magnetic ref sensor.
Postby Dragon on Tue Aug 20, 2013 11:45 am
MoTec's 52002 works well.
Dragon
Users browsing this forum: Majestic-12 [Bot] and 13 guests
