LS coils
Includes MoTeC CDIs, Ignition Expanders
LS coils
Postby otto69 on Sat Jul 20, 2013 9:03 pm
Looking at fitting LS coils to a 302W with M84.
What model would be the best, LS1, 2, 3, 7 etc ??
Can I gang two together for waste spark straight from the ECU ??
Does anyone have the setup details for the coils (wiring & valves) ??
cheers
Clayton
otto69
Re: LS coils
Postby stevieturbo on Sun Jul 21, 2013 4:25 am
otto69 wrote:Looking at fitting LS coils to a 302W with M84.
cheers
Clayton
Whatever is most easily available. They are all very good coils. The favoured D585 truck coils seem to be harder to get hold of these days.
After that I think the square D510C are preferred and then the D514A after that.
Sidenote, do not buy from a seller Evalero1 on ebay, he sells cheap chinese copies that will fail within minutes.
Yes you can fire them as wasted spark by pairing the ecu outputs.
Just google "LS2 coil pinout" on google or google images. There is plenty of information on their wiring.
As for specific Motec values...not sure.
These coils require a 5v signal to charge, and when this is removed they fire. falling edge. Dwell time would typically be 4ms.
Some may allow more, but 4ms is usually plenty for most applications.
stevieturbo
Re: LS coils
Postby pftuning on Sun Jul 21, 2013 1:07 pm
Agree on the Chinese copies; they have a terrible reputation.
Peter Florance
PFTuning
Virginia Beach, VA 23454
http://www.pftuning.com
pftuning
Re: LS coils
Postby otto69 on Sun Jul 21, 2013 10:11 pm
Thanks for the great info Stevie, has helped heaps.
Clayton
otto69
Re: LS coils
Postby AdamW on Mon Jul 22, 2013 7:40 pm
Also be aware that some of the LS type coils dont work well with the Motec ignition expander - so if you are going to use an IEX as part of the install or maybe even thinking that about one as a future upgrade option then it would pay to confirm your options with Motec before commiting. I'm pretty sure it is the LS2 coils that dont like the long dwell that the IEX outputs at cranking RPM.
Motorsport Electronics Ltd.
AdamW
Re: LS coils
Postby otto69 on Mon Jul 22, 2013 8:20 pm
Thanks for the heads up Adam
Recon I'll stick to wasted spark, so that means I could use any of the LS coils in pairs ??
Clayton
otto69
Re: LS coils
Postby stevieturbo on Tue Jul 23, 2013 4:11 am
otto69 wrote:Thanks for the heads up Adam
Clayton
As far as I know that would be correct.
stevieturbo
Re: LS coils
Postby otto69 on Tue Jul 23, 2013 10:18 pm
otto69
Re: LS coils
Postby otto69 on Tue May 13, 2014 3:43 pm
Just to confirm wiring up wasted spark, if the firing order was 1-3-7-2-6-5-4-8
I would connect
Ign1 to coils 1 & 6
Ign2 to coild 3 & 5
Ign3 to coils 7 & 4
Ign4 to coils 2 & 8
Clayton
otto69
Re: LS coils
Postby stevieturbo on Thu May 15, 2014 4:53 am
otto69 wrote:Just to confirm wiring up wasted spark, if the firing order was 1-3-7-2-6-5-4-8
I would connect
Ign1 to coils 1 & 6
Ign2 to coild 3 & 5
Ign3 to coils 7 & 4
Ign4 to coils 2 & 8
Clayton
Correct as long as ignition outputs fire in the order listed, 1, 2, 3, 4.
stevieturbo
Return to Ignition systems
