Fuel injector Clinic (FIC1050)
Postby niv1812 on Mon Jul 22, 2013 7:20 pm
Hi guys,
Hope someone can help me out. I just got a pair of FIC1050cc low impedance injectors and i'm fitting this on an STI version 7 with M800 ecu. I would like to know which base map i can use and also i you can help me to configure the injectors as I didn't got any documents for the dead time.
Thanks a lot.
Cheers,
Niv
niv1812
Re: Fuel injector Clinic (FIC1050)
Postby stevieturbo on Tue Jul 23, 2013 4:13 am
niv1812 wrote:Hi guys,
Thanks a lot.
Cheers,
Niv
M800 gold box or plug n play ?
If you dont have the data or cannot get it, then wouldnt worry about it too much. Surely FIC would be able to supply you it though ?
As for base map, use whatever is most appropriate for your car's spec, but no doubt if you are using such injectors, it is far from standard anyway. So any "base" map will need a lot of work.
Is the car even running at present ?
stevieturbo
Postby niv1812 on Tue Jul 23, 2013 6:35 am
Hi mate,
Thanks for the reply. I'm using the subaru base map ver7 which is on the website and the ecu is the gold box. I just got the battery compensation with fic and the injectors are 2.2ohms, any idea what i should setup again, my fuel pressure is 45psi. Thanks for your help.
Regards,
Niv
niv1812
