I cannot find any specs on the correct temp sensor to work with a 2Group ECU, nor can i find any way with the hand-controller to calibrate a sensor.
this engine package appears to have been using a stock Toyota/Denso water temp sensor for years, but the hand controller tells me the ET is 80C when its more like 25C. I suspect this is the reason why its such a pig to start as the cold-start functions dont work????
can anyone assist?
thank you
