by trucker on Sun Jun 23, 2013 7:23 am
I have a Motec M84 ecu and I have been reading everything I can find to educate myself on the features. For right now though I only need to know how to do two thing's and that's to check the air fuel lambda mixture and make adjustments if its rich or lean. My question is after I make a pass down the drag strip and plug my laptop in and open the ecu manager. Where do I look to check my lambda? And how do I adjust it if it's lean or rich? I want to keep my lambda between 0.80 and 0.85 any help will be greatly appreciated. Or how do I use the quick lambda feature? My lambda fuel table is setup. Thanks in advance.
