AEM AFR meter as second lambda
Re: AEM AFR meter as second lambda
Postby scoobyman on Sat Jun 01, 2013 12:32 am
Steve, you are a hero!
I will definitely give this a shot, as it seems like this is the answer i was looking for! :mrgreen:
Try this...
Sensor setup
Input Setup
Select La1 and click change
Input Source=Select the AV input you are connected to
Calibration= Wideband Lambda 3 decimal places
Click the custom table option
Open the table and input your voltage output table from your AEM.
HTH
Steve
scoobyman
Postby stevesingo on Mon Jun 10, 2013 8:20 pm
Did you have any luck with this?
stevesingo
Postby Pavlo on Wed Jun 12, 2013 4:33 am
The NTK/Bosch sensor calibration is only applicable if the sensor type in "Adjust->Sensor Data->Wideband Lambda sensor->Sensor setup" Is set to anything other than 0 (zero). For your AEM sensor you will need to set La1 or LA2 (whichever you're using for the NTK) to 0 (zero).
Using "Adjust->Sensor Setup->Input Setup" you can input the AEM into Lambda1 or Lambda2 (whichever you're not already using) and select the sensor as "#39 Lambda: MoTeC PLM or AFM1" which will allow you to scale the input to match the output of your AEM, whatever it is.
Pavlo
Previous
Users browsing this forum: Google [Bot] and 0 guests
