Can someone please post the schematic and pinout for the CDL3 terminated loom that comes with the track kit? I need to modify mine and would rather not have to trace everything. Thanks in advance.
--Peter
Herrubermensch wrote:Does the can 2 connection for the GPS have a terminating resistor built in? I know the ECU connection has one. I am connecting my CL3, LTCD, etc. to an existing CAN bus (that has two terminating resistors) off of which I run my PDMs and am trying to figure out which of the CAN bus connections to use. Thanks.
AdamW wrote:The standard Motec GPS receivers are serial not CAN. The racegrade GPS is also normally serial coms although I think they can supply a special CAN version. Are you sure yours is the CAN version?
