Hi there,having problems getting latest project fired up. Engine L28 nissan, VL rb30 distributor 360 ref slots,6 Sync slot(one larger home slot).M84 ecu, 6 LS1 ignition coils. The problem is i get no spark with the general setup-main setup setting shown on drawing T10 Nissan 360 slot optical drawing for a rb30 engine.Ref/Sync mode 10 Crank Ref 180 and Crip at 60. If i change the CRT to 60 i get all the coils to fire at once per dist.cycle. Is there other settings i should try that are not on the web site. I have the ignition set to 6 coils and can test them and all work fine in their firing order.have checked the input signals to ecm and look fine. Have set the REF and SYNC filter table to 0.
Hope someone has some helpful info for me. thanks.
