knock module
SKM and OKM
Re: knock module
Postby r.hellenbrand on Mon Sep 29, 2008 6:35 pm
Which analogue inputs can I use to measure the knock signal?
Is there a list with sample speeds from AV and AT inputs?
Thanks,
Ron
r.hellenbrand
Re: knock module
Postby Dragon on Mon Sep 29, 2008 10:26 pm
You can use La2 or AV inputs, former being preferable.
Dragon
Re: knock module
Postby Pascal on Thu Oct 02, 2008 7:46 pm
Any official standings about knock module and availability? C'mon MoTeC guys! Share it please, we need that medicine too! ;) ;)
Cheers Pascal
Pascal
Re: knock module
Postby Jon K on Wed Oct 22, 2008 12:31 am
This looks interesting - how "standalone" is this? I am running another ECU but I am looking for reliable knock sensing. I have a few ADC inputs that would be great for logging into my other platform. Is this unit supposed to be standalone or does it require a MoTeC box?
Jon K
Re: knock module
Postby SprinterTRD on Wed Oct 22, 2008 8:26 am
The module needs certain signals to operate correctly that is generated by the MoTeC ECU, I doubt that other ECU's will have them
SprinterTRD
Re: knock module
Postby JamieA on Mon Oct 27, 2008 9:26 am
See this link for more details
http://www.motec.com.au/aboutknockcontr ... koverview/
But to summarise. Yes, the latest Motec hundred series software can do closed loop knock control, but you need to use the motec knock module.
The knock module takes in the signal from knock sensors, as well as a knock window from a MoTeC hundred series ECU. (A knock window is an ignition timing based signal, generated by a MoTec ECU, used by the knock module to tell it to only listen for knock during a defined window based around an ignition event)
So to do this, you need
a standard knock sensor
A Hundred series MoTeC ECU
A MoTeC knock module
-Jamie Augustine
JamieA
Re: knock module
Postby stevesingo on Tue Oct 28, 2008 12:07 am
Is there any RRP for the SKM?
Steve
stevesingo
Re: knock module
Postby JamieA on Thu Oct 30, 2008 2:28 pm
The RRP will change from region to region, (due to the usual factors, exchange rates, freight, taxes etc) so just talk to your local dealer an they will be able to give you a local RRP...
-Jamie
JamieA
Re: knock module
Postby jeremyj2e on Sun Nov 02, 2008 11:12 am
Does the standard 100 series ECU not have knock control? Meaning you can't use the factory knock signal without this extra box?
jeremyj2e
Re: knock module
Postby JamieA on Mon Nov 03, 2008 11:25 am
That is correct, the standard hundred series ECU wasn't designed with the hardware required to setup the appropriate frequency based signal amplification of knock sensor inputs, run the hardware signal gating, etc, etc.
To do knock control properly is a major task, and we have specially built knock control modules to perform this function, passing back to the hundred series ECU only what information it need to do the closed loop control.
-Jamie
JamieA
PreviousNext
Return to Knock Modules
Users browsing this forum: No registered users and 40 guests
