Which sync/ref model suitable for 1GR FE engine?
Postby MichaelLee on Tue Apr 30, 2013 7:23 pm
I have attached Sync signal.
[img]1GR.JPG[/img]
MichaelLee
Re: Which sync/ref model suitable for 1GR FE engine?
Postby Martin on Wed May 01, 2013 3:59 am
Mode 33 on the M800. Ive got a lot of 1GR FE configs and could help you if you want.
Postby MichaelLee on Wed May 01, 2013 1:57 pm
Thanks, Martin. I will try 33 mode on the M800. The best there is a start file if you can supply.
MichaelLee
Postby Martin on Wed May 01, 2013 5:41 pm
pm me your email address
Postby stevieturbo on Thu May 02, 2013 3:51 am
delete
stevieturbo
Postby MichaelLee on Fri May 31, 2013 2:40 pm
Martin wrote:pm me your email address
Hi Martin
I have setup sync/ref same with your map, but the ecu still can't synchronized(show "error sync signal").
MichaelLee
Postby Martin on Fri May 31, 2013 4:04 pm
post a ref sync capture and your config
Postby MichaelLee on Sat Jun 01, 2013 8:11 pm
Martin wrote:post a ref sync capture and your config
I have attached a sync signal capture and config
1gr setup.JPG (96.59 KiB) Viewed 20931 times
MichaelLee
Postby Martin on Mon Jun 03, 2013 3:01 pm
Your ref sensor edge is incorrect. Should be falling.
