M400 baud rate for RS-232
Postby cmcrae on Fri Apr 19, 2013 3:44 am
I've been having trouble reading the correct data from a data logger I'm constructing. It gets data, including the headers of $82, $81, $80, but after that the data seems to get corrupted. I saw in the data sheet that it said "baud rate 19200 (actual 19231)". I tried this but it didn't seem to work; my question is, is the baud rate from the ECU in this case 19200 as stated by ECU Manager, or 19231 as stated by the CRC32 data set sheet?
cmcrae
Re: M400 baud rate for RS-232
Postby MattW on Fri Apr 19, 2013 10:29 am
Hi cmcrae,
The requested baud rate of 19200 becomes 19231 actual because of processor clock speed.
That's an error of only 0.16%. You should get away with 0.5% before coming across issues.
MattW
Return to MoTeC PC Comms
