Gear table from shifter X and Y voltage inputs?
Postby pftuning on Wed Apr 10, 2013 4:27 am
Can the M800 determine which gear the driver is in based on two voltage inputs?
The Nissan 370z (Fairlady in other markets?) uses two sensors on the gear shift to detect L-R and forward-reverse positions of the shifter. The team engineer would like to know the gearshift position itself. Is that possible in the M800 or can I derive it later in a log, if I log both voltages?
I've verified the service manual's voltage chart:
X Axis
N: 1.45 - 2.35 V
1st: 0.90 - 1.40 V
2nd: 0.90 - 1.35 V
3rd: 1.70 - 2.15 V
4th: 1.65 - 2.10 V
5th: 2.70 - 3.15 V
6th: 2.65 - 3.10 V
R: 3.50 - 4.05 V
Y Axis
N: 2.15 - 3.00 V
1st: 1.10 - 1.60 V
2nd: 3.40 - 3.90 V
3rd: 1.10 - 1.65 V
4th: 3.40 - 3.90 V
5th: 1.10 - 1.60 V
6th: 3.40 - 3.90 V
R: 3.40 - 3.90 V
I'm wondering if I can set up some sort of table who's output is Gear, but not sure if that is possible in M800.
Thanks!
Peter Florance
PFTuning
Virginia Beach, VA 23454
http://www.pftuning.com
pftuning
Re: Gear table from shifter X and Y voltage inputs?
Postby pftuning on Sat Apr 13, 2013 1:08 am
I ended up sending the X and Y sensor values to the CDL3 and made a Gear table there.
Peter Florance
PFTuning
pftuning
Users browsing this forum: No registered users and 36 guests
