Hi I want to use my analog output2(wideband) from my LM1 into an input of a subaru MY99 pnp board for dataloging purposes.
What pin should I use? What pins do I have available?
best regards,
joe
stevieturbo wrote:And scale the 0-5v output to cover as narrow an AFR range as possible.
For some reason, when I used the MTX analgoue output into the Motec, there were huge voltage irregularities. Even when tested at flatline voltages, there were errors up to about 0.4v ! Strangely, not fixed errors, the voltage actually fluctuated.
So I'd use it purely as a logging reference only.
Not sure if the problem was MTX related or wiring, never did investigate further. Think I used
0.1v = 0.5 lambda
4.9v = 1.5 lambda
It will never go to either extreme, but it was just how I set it.
Karel wrote:stevieturbo wrote:And scale the 0-5v output to cover as narrow an AFR range as possible.
0.1v = 0.5 lambda
4.9v = 1.5 lambda
You will always need to use good grounding and sensor groud is something what is related to sensor input volatage too. If you just put the signal from WB lambda to ecu you can see some voltage drift acordinghow good or bad your car, ecu and engine grounding is.
