Try more injection timing and will be better.
tried on my evo with motek m800 pnp something like 450 and become better to -5 -10
scoobyman wrote:Thanks for that, i'll try those changes and see how it works today.
The car is actually running quite rich once its started, its jumping between 12.5-13,7 AFR after just starting and once ET is over 80 C it settles around 12 AFR..
It has been unaffected by my playing around with compensations as far as i can tell, it always idled very rich.
While driving, at constant throttle and no boost, i have 13,7-14.2 AFR.
Is there maybe something i could log for you guys that could help analyze this problem ?
Thanks!
scoobyman wrote:Thanks Holmz,
Here are my current ignition tables, could you recommend any cold start changes i should make ? I have absolutely no idea what range of value changes are acceptable and which are not.
Users browsing this forum: Bing [Bot], Google [Bot] and 35 guests
