M880 Subaru loom
M880 Subaru loom
Postby Robbied on Sun Mar 24, 2013 12:37 am
Hi all,
I have a query regarding wiring of an M880 , I hope you guys can help! I've made a number of both chassis and engine looms (raychem and AS connectors, mil-spec) but this is the first time designing/building one for an M880. This will be for my own track day car...
Can I drive the early subaru coils directly from the M880? If so do I just wire directly to the ignition O/Ps? I'm using the slightly smaller coils circa 1995-1997...
I'm sure I'll have a more questions as I get on with the harness design!!
Thanks,
Robbie
Robbied
Re: M880 Subaru loom
Postby stevieturbo on Sun Mar 24, 2013 1:40 am
Which Subaru coils ?
most early Subaru's had 2 wire coils which must use an ignitor.
Some Legacy's used 3 pin coils which had internal ignitors. 2001+ Subarus pretty much all have 3 wire internal ignitors.
Easiest thing if you want a coil on plug with built in ignitor is to source some suitable coils.
Or the 99/00 with the coilpack to the side of the intake manifold has internal ignitors.
97/98 with coil pack in centre of intake require an external ignitor
stevieturbo
Postby Robbied on Sun Mar 24, 2013 4:50 am
Great info thanks,
I think I'll wire it with the conventional ignitor that way whichever coils i end up using (likely early 2-wire type) I'm covered,
Next question(!), what's the best o/p to use to send an RPM signal into the chassis loom? It will end up at a stack display only for now,
Robbied
